need a little help
gravesdu_99
255
Potsdam
Need a little help with what this is. I was doing a leak test and I found air leaking out of this part. I'm not sure if I broke it or if it is the way it was made. It goes on the inside of the 1jz intake next to what I believe is the air temperature sensor. Also near the idle control valve. If it is broke does anybody know where I can get one or of anybody that has one for sale.
YotaRob
U.S.Navy
Jun 18, 2008
177
Great Lakes
That little guy is what your map sensor vacuum hose hooks up to. it is like a little dampner I believe. I think the 2jzgte usdm has one also, or try champion toyota and see what they can do for you.
Edit:yes it is broken
gravesdu_99
255
Potsdam
Thanks for the help, I'm running a stinger standalone so I don't have a map sensor and probably no need for that sensor. So I'll find a plug to go there.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
yup you shouldnt need it
