my dyno runs 7mgte
dumbo
1,913
Albera, Too Far North
supraguru05;1222646 said:
switching from the na cam to the turbo cam i didnt notice the power loss down low because your only there for a split second i definitly noticed the gain up top however.
my answer is that the turbo cam is better for BOTH autocross and road racing than the NA cam. i have 5 years of autocross under my belt with a 7mge for 4 of them and the 7mgte for last year both with the NA cam and turbo cam and the the turbo cam made a big difference. also switching from 4.3 rear gears to 3.73 helped in autocross to my suprise.
awesome man good to hear; i'm eagaerly awaiting my swap:)
gotta post some of your autox videos, i'm sure they'll get some attention, peace
supraguru05
Dec 16, 2005
737
louisville ky
suprafanatic;1223546 said:
are you running a FFIM in those vids??
yes its a simple one cut a hole in the front of the stock manifold and weldedon a pipe and flange. didnt flow bench it but i assume the air flow is distributed decently although that may be a reason why my afrs are so off its possible that a clyinder might be starved.
videos are posted in the video section if i post them here i will get cited with a violation so go check out the video section
