My car ejaculated on me
JBatt87T
102
Athens, GA
Yes thats correct. I just took my first cruise in my car since the turbo upgrade and on my way home I poped an IC hose off, so I limped it back and found that that wasn't my only problem. There is oil all over my fuel rail and in pools on my lower runner. I haven't really looked too hard to see where it is coming from, but it has pretty much spewed all of the oil onto my garage floor. This blows big nuts. What do you guys think has happened? It hasn't came out of the valve covers so that is out, and seems to be coming out evenly across the side of my motor.
Help please!
Jake
Dirgle
Conjurer of Boost
Pauma Valley, CA
Which IC hose pooped off? If it was the upper one at the 3000 joint then it could have blew some of the oil that sits down in our intercoolers, across that side of the engine. Just a guess.:dunno:
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
Crankcase vent tube that would be hard to blow that much oil from that tube at the top unless you got some serious blow by at the pistons I also believe its from the IC pipe
JBatt87T
102
Athens, GA
Yeah I was thinking that teh crankcase vent tube may be the culprit as well but it doesn't seem to be coming from there. Where would it be coming from if it is the IC pipe though? Cause there is no IC piping around the leak. I did see a good amount of oil in the top IC pipe though.
JBatt87T
102
Athens, GA
That seems to be the general consensus. I have a aftermarket IC waiting to get put on, just gotta get the pipes made.
JBatt87T
102
Athens, GA
Well I just took off the manifold and the crankcase vent tube the tube has a crack about an inch and a half long at the top side, dunno if that's it but it seems that the majority of the oil is around it.
JBatt87T
102
Athens, GA
Replaced teh crankcase vent tube and it is still leaking oil everywhere! Could it possibly be the headgasket? Im cunfusked:wtf:
supra90turbo
shaeff is FTMFW!
MA, 01440
My friend's supra had a similar problem, it turned out that the cam seals were bad, and the timing belt was whipping oil all over the engine bay, I mean, the entire bay was COVERED...
My advice:
Clean the shit out of the engine bay. Go buy some Engine Oil Dye, apply to the crankcase. Run engine for about a minute, then shut down. Check over engine bay with a blacklight. (procedure best done at night or in a semi-enclosed structure that blocks most natural light).
HTH
