In the world of Monopoly Go, success depends heavily on your understanding of dice mechanics. Whether you're aiming to climb the leaderboard, win bank heists, or complete epic events, how and when you use your Monopoly Go dice plays a vital role in your progress.
This comprehensive guide will help you master dice usage, teach you how to get more dice for free, show you optimal strategies for using multipliers, and explain how dice probability affects your game. Let’s roll into it!
In Monopoly Go, every move is based on a dice roll. Dice rolls are random, but how you manage your dice can make a big difference in your results. You roll the dice to move your token around the board, and the outcome of each roll determines the space you land on.
Each roll consumes at least one die, but you can increase your dice multiplier to use more at once in exchange for potentially greater rewards.
The dice multiplier lets you roll multiple dice at once (e.g., x1, x5, x10, x20, x50, x100). It does not affect the number you roll—it only affects the rewards you receive if you land on a bonus square or win an event.
If you roll with a x20 multiplier and land on a reward square, you'll receive 20 times the base reward—but you’ll also consume 20 dice in one roll.
Dice in Monopoly Go follow standard probability:
This is based on basic dice math: more combinations result in 6, 7, or 8 than any other total.
If you’re 6 to 8 spaces away from a key tile—like a Railroad, Shutdown, or big reward—you have the highest chance of landing there. This is when you should increase your multiplier to get the best possible return.
Using your dice wisely means knowing when to use the multiplier and when to conserve your rolls.
Never use high multipliers randomly—you’ll burn through your dice and get less value.
Two of the most exciting features in Monopoly Go are Bank Heists and Shutdowns. Landing on Railroad tiles triggers these events.
Running out of dice is a common problem—but there are many ways to get more dice in Monopoly Go for free.
One of the biggest mistakes new players make is using dice too quickly.
You may come across Signature Dice in Monopoly Go, which offer cool animations and styles. While they don’t affect gameplay, they add a fun, personal touch to your rolls.
You can unlock Signature Dice by:
Every time you complete a board or reach a new level in Monopoly Go, you’ll receive bonuses—which often include large dice packs.
The higher your level:
So, play smart. Focus on rolling efficiently, collecting properties, and maximizing rewards to level up faster and earn more dice.
Stickers are another core mechanic in Monopoly Go. Completing a sticker album or even individual sets gives massive dice bonuses.
Tips:
Here’s a quick checklist to help you dominate the board:
Yes, dice rolls are fully random. However, you control the reward value using the dice multiplier.
Use it when you're 6–8 spaces away from a valuable tile. The probability of rolling 6, 7, or 8 is the highest, making these optimal targets for high multiplier rolls.
You can earn dice by:
No. The multiplier doesn’t affect chances, only the reward if you do land on those tiles.
Yes, but only when you’re near a high-reward tile like a Railroad, especially during a major event.
There’s no official way to get unlimited dice. However, you can consistently earn large amounts by following daily tasks, events, and sticker completions.
Signature Dice are custom-designed dice skins you can unlock. They are purely cosmetic and don’t affect gameplay or roll results.
Mastering Monopoly Go dice isn't just about luck—it's about timing, strategy, and smart resource management. With an understanding of how the dice multiplier works, the importance of dice probability (6-7-8 rule), and how to earn free dice, you’re already ahead of most players.
Whether you're chasing down a bank heist, completing your sticker album, or rising through the levels, dice are your most valuable currency. Make every roll count!
CLICK HERE TO GET IT FREE
How Monopoly Go Dice Work
Key Points:
- Dice outcomes are random, but the rewards you receive are affected by your dice multiplier.
- You control how many dice you want to use with each roll.
- Managing your dice wisely ensures long-term play and strategic advantage.
What is the Dice Multiplier?
Example:
Best Practices:
- Use x1 when you're far from valuable tiles.
- Increase to x20 or x50 when you’re close to a target tile (like a railroad or bank heist).
- Save x100 for extremely high-value moments or limited-time events.
Dice Probability: Understanding the 6-7-8 Rule
- Most common roll = 7
- Next most likely = 6 and 8
Strategic Takeaway:
How to Use the Multiplier Effectively
Smart Multiplier Strategy:
- Use x1 most of the time, especially on blank or low-value parts of the board.
- Switch to x20–x50 when you’re 6–8 spaces from:
- Railroad tiles (Heist or Shutdown)
- Tax refund or Go tile
- Property upgrade opportunities
- Event tiles
- Save x100 for:
- Mega Heist chances
- Special events with leaderboard bonuses
- Sticker milestone rewards
Bank Heists and Shutdowns: Maximize Rewards
Bank Heist Tips:
- Use a higher multiplier before hitting a Railroad tile for a potential heist.
- Monitor your progress: If you haven’t hit a big reward in several attempts, the next one might be a jackpot.
Shutdown Tips:
- Shutdown events allow you to "attack" other players and earn big bonuses.
- Again, if you're 6–8 spaces away from a Railroad, increase your multiplier for a better payout.
️ How to Get More Dice in Monopoly Go
Ways to Earn Free Dice:
- Daily Rewards – Logging in daily gives you free dice.
- Completing Boards – Each board has multiple levels; completing one often gives 50+ dice.
- Event Participation – Compete in special events for leaderboard placement and dice bonuses.
- Sticker Albums – Completing a sticker set can earn you hundreds or even thousands of dice.
- Color Wheel – Spin for daily prizes, including dice rolls.
- Invite Friends – Get extra rolls by inviting new players or helping friends complete tasks.
- In-App Promotions – Limited-time offers, mini-games, or challenges frequently give out free dice.
Dice Management: Saving vs Spending
Do:
- Save dice for multiplier moments.
- Wait for special events to maximize roll value.
- Keep your dice above 500–1000 if possible for burst rolling during promotions.
Don’t:
- Waste high multipliers on low-value tiles.
- Use x50 or x100 just because it’s available.
- Roll aimlessly when you don’t need event points or rewards.
Signature Dice: Style Over Strategy
- Completing sticker sets
- Earning event milestones
- Participating in seasonal promotions
Leveling Up for Dice Bonuses
- The more expensive upgrades become
- The more rewarding the milestone bonuses
Stickers and Dice Rewards
Tips:
- Trade duplicate stickers with friends.
- Use sticker events to complete sets faster.
- Focus on finishing sets during limited-time events for extra dice.
Quick Recap: Monopoly Go Dice Strategy
Use x1 multiplier unless close to a target.
Save x50–x100 for Railroads or event tiles.
Stay alert to 6–8 tile distances for maximum roll efficiency.
Participate in all events to earn free dice.
Complete sticker sets for major dice rewards.
Avoid wasting dice on blank or low-reward tiles.
Keep dice saved for future events and promotions.
FAQ: Monopoly Go Dice
Q1: Are dice rolls in Monopoly Go random?
Q2: What is the best way to use the dice multiplier?
Q3: How do I get more free dice?
- Completing daily missions
- Participating in events
- Spinning the Color Wheel
- Leveling up your board
- Inviting friends
Q4: Does using a multiplier affect my chances of winning a heist or shutdown?
Q5: Should I ever use x100 multiplier?
Q6: Can I get unlimited dice?
Q7: What are Signature Dice?
Conclusion
