Model differences???
Josh21040
Columbia SC
Does anyone know if there is a difference in the subframe and front suspension from a 1986 1/2 to a 1990? My 1990's front subframe is trashed, and I know someone that has a parts car for a good price. Its a non-turbo 5 speed. If the parts will fit for the suspension, I can get the car and swap the transmission as well. Mine is an automatic, turbo. I know the transmission can't hold as much power, but I am not going to have many mods to my car. So what parts are/aren't interchangeable?
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
yes it is. it will not work with your car because of the different engine mounts it comes with. The transmission will bolt up completely to you're but it used a different clutch slave cyl iirc, or some sort of different plumbing. but yeah easy as pie :D
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
Rajunz said:
Yes the blocks are the same, suspension components are the same.
NO their is differences in the years because their is two types of motor mounts the square type like in the older supras mk3 supras and the circular type like in the newer mk3 supras.
89TBen
97
Mizzou
can't you use the older motor mounts on the newer engine though? i think you can but im not sure. but if you can than he would be fine 'cause hes gonna use the 86.5 subframe and the square engine mounts. right? but anybody correct me if im wrong, cuz im not 100% sure on this.
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
Yes you can use older motor mounts on a newer engine because I have a 1991 JDM motor and I used the stock 87 motor mounts for my 87 supra so if he is going to use the square motor mounts in the 86.5 subframe then yes it will work:biglaugh:.
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
Rajunz was saying that the suspension components are the same, which they are.
Also that the blocks are the same, which they are.
The crossmember itself is different, but if he grabbed a crossmember and mounting brackets from an 86.5-89, everything would bolt up into his 1990.
