Hey everyone,
Its been a while since I made a build thread (cough http://www.supramania.com/forums/showthread.php?t=81005 cough) but the Supra has been a great daily driver since I did all the proper maintenance from back then. I have been hoping for something to go wrong with the original 7mGTE motor to kick off my JDM 7mGTE motor rebuild with 31k I got in 2007 sitting in the garage but no luck with that if that makes any sense. In early of 2017 I was able to find a great deal on a non running turbo manual Supra for less than the cost of a r154 manual transmission by itself so with that purchase the ball started rolling to get this rebuild going on my 87 turbo Supra. Overall the 7m I wanted is a very reliable motor with no short cuts or cheap parts put in and a power goal of between 500 to 600 whp on e85.
The current status of things as of today. The Supra is in the garage for the winter. Everything is broken in on the rebuilt motor with no problems at all and it has around 1k miles on it but everything is just at OEM power levels with all the factory parts/electronics. I still need to install the 1200cc fuel injectors, ECU Masters standalone and redo the whole engine harness with new wiring so then I can get it dyno tuned at Sound Performance.
I would also like to personally thank everyone today to over the last 10 years for all the great information this site has provided, the part sellers in the classifieds section, the build threads and those who have shared their mistakes with us to learn from. Without all this, I know this build would not have turned out as amazing as it has so far.
Engine Parts:
Ishino gasket set
AZ Performance oil pump hard line
BC 264 camshafts
COMP 975 valve springs
Sound Performance Precision 6262 bolt-on turbo
Gates Racing timing belt + KOYO timing belt tensioner
clear timing cover
ARP head studs
ARP main studs
Fidanza cam gear set
Remain A1-Cardone CPS unit
CPS cover
Cps magnet mod
Gates coolant hose set
Eagle rods w/ARP bolts
Wisco pistons
AZ Performance EGR block-off plate set
7m heater outlet pipe kit
Clevite bearing set
polyurethane motor mounts
HKS SSQV BOV
Drift Motion intercooler kit
oil catch can
oil pump
Thermostat
Water Pump
Fuel & Electronics:
AEM air/fuel gauge + wide-band
Ethanol content sensor
Marshall fuel pressure gauge
1200cc Precision fuel injectors
Aeromotive fuel pressure regulator
Walbro 450 (F90000274) fuel pump
Magna fuel filter
GM intake air temp sensor
Blue Sea 5045 fuse block holder
31' of AN6 PTFE stainless steel fuel line
AN6 fittings x28
Acura Legend fuel injector resistor box
2jz DH61 igniter
2jz Denso coils
2jz NGK spark plug wires
Transmission & Drivetrain:
Clutch Master FX400 clutch kit
rebuilt differential
Shaft Masters aluminum driveshaft
stainless steel clutch line
ARP flywheel bolts
lightweight steel flywheel
slave cylinder
clutch fork
throwout bearing
pilot bearing
master cylinder
OEM shifter
shift boot
lower speedo cable
Suspension & Steering:
outer tie rod set
power steering filter
power steering pump rebuild kit
power steering belt
Energy sway bar bushing set
remain rack & pinion
Now let's get the pictures rolling 56k beware (for the old members that remember that:evil2
Pictures of the JDM motor it is original state:
Most of the motor parts going in:naughty::
Cleaning, preparing and painting some parts:
Modded the J Tube plate and removed that restrictive pipe:
Comparing my old long gone 87 BHG to the BHG on the JDM motor to the metal head gasket:
Engine Parts:
Ishino gasket set
BC 264 camshafts
clear timing cover
ARP head studs
ARP main studs
CPS cover
Cps magnet mod
Wisco pistons
Clevite bearing set
HKS SSQV BOV
oil catch can
oil pump
Thermostat
Water Pump
Fuel & Electronics:
Magna fuel filter
AN6 fittings x28
2jz DH61 igniter
2jz Denso coils
ARP flywheel bolts
slave cylinder
clutch fork
throwout bearing
pilot bearing
master cylinder
OEM shifter
shift boot
lower speedo cable
outer tie rod set
power steering belt
