MKIII Rear Strut bars
Turbo Habanero
4,229
Tucson,AZ
Buy sway bars there's a Suspension Techniques Kit for around $300 Not sure it its good or not maybe do some research and find out. but more then likely a big upgrade for the car.
Or Tanabe but im not sure on the price of those or the qaulity on ethier product.
ubersonic
68
Wales
Wierd, like I said in the UK rear strut bars make a night and day difference to the handling of the MKiii, its the first modification people recommend for an aerotop, guess we just have more corners ^^
Turbo Habanero
4,229
Tucson,AZ
IDK im sure that's not 100% the case Buddy.
I am pretty sure the guys on here are not just blowng some smoke up your butt. And there's some research and truth to what there saying.
but listen if you will if not i gues it's your money spent.
te72
Classifieds Moderator
6,624
9
WHYoming
Nah, I think its just the weather in the UK. Does funny things to car engineering. :p
bioskyline
1,236
powell river bc
well there is a test to see if your strut bars do something.
take the bar off, and make a paper gasket thats the same as the bar mount. bolt it all back up and take it for a spin, then pull the bar off. if the paper is torn or marked up, then it is doing something. if its not damaged, the bar is doing nothing.
Turbo Habanero
4,229
Tucson,AZ
there you go now someone go test it out. I would but i don't have a Strut Bar
hachibill
22
florida
If any of u would have taken a mk3 apart u would relize u dont need a rear strut bar cause the car has one built in from the factory.......
The raised part between the shock towers is actually not the floor. Thats all added structure just to reinforce the rear shock towers.
