mk3 supra getting the axe oh well every one saw it coming
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well sad to say i killing my old 86.5 race car project i had nice build thread going but every time i look at it it just burning barrel of money it just need to much for me to be happy had it for about 7 years and served me well and tought me alot of things
now on with the new i still do have my 92 and such
still de bateing if i should shart a new project 82 to 86 notch ceica gt wiht ford nine in the back tube and all wiht all my old power adder's
or drop it in the 92 when the day comes
old car spec's
well frist off i must say i have bena playing wiht my car for 6 yeasr and now that i look at it i impressed all list my mods list
shell 86.5
887mgte 9.3.1
ross piston 20 over
cusotm cam's
cfs race rad
obx cam gear for a 2j
b&m oil cooler
shoot peed stock rods
cevit bareings
arp hard were
arp studs at 90 foot pounds
titan hg
no egr
ss manfold
pte 67 p trim trubo (780hp)
garret ic 31x 16 3.5
tial 50 mill bov
tial 46mill waste gate
3.5 inc down pipe
4 inc dp back stain less exhaust wiht burns 4 inc race muffler
nogly hot wires
Nm shifter
Nm cusotm rear sub frame
Nm custom semi soild sub fram spacers
Nm trailing arm's
Nm custom wheel adtor hub
kvr drill rotors
poter feild pads
stain less lines
st sway bars
battey sunk into the floor in the back where the spare tire well used to be
kill switch
4.30 rear diff
fudenza light weight fly wheel
hpf broze clutch
act clutch cover
stain less clutch line
Nm custom ic piping
lex afm
lex thottle body 75mill
580 injectors
aermotive fule reg
all stian less fule lines wiht an fittings
NM custom oil pan
momo t2 seast
grant streeing wheel
greddy boost and egt warn gauges
auto meter shift light\water temp\oil persure\oil temp\air fule\ to be added is no2 and fuel persure
zex no2 kit soon to be added just got other stuff to install frist
NM custom ic sparyer
Nm cusotm front impact bumper
hood pins cause there cool
eb spring's
bilstain shocks
rci 4 point belts passger and drive
nm cusotm back bracing strut bar and center brace
apexi avcr
apexi safc 2
greddy turbo timer
greddy catch can with in line filter
trd oil cap
custom drive shaft aulim
Nm custom tranny polly monte
89 wing
qutom racing wheels 235 front and 255 back kumho mx's
vipper alram it pages me so don't think abotu it
plx wide band o2
fuel pump re wire 12 volts
warrbro 255
greddy front strut bar
apexi air filter
eletrica fan
nm cusotm intake manfold
hella fog lights
nm custom hood
semi solid motor montes
nm cusotm end links
NM cusotrm brake pedal arm
greddy rebic lc
et street drags
stuff i have ditch hummmm alot
no power streeing
no ac
no egr
no abs
no sound deaning in the hole car peried
gutted carpet
no heater
gutted under dash bord
miss bracing cut out
this is my mods list once i find nice place to host all my pics when done
ps this mods list all wasy grows so stay tuned and i have done more stuff but really can't remmber it all
i will be taken down teh build threqad in cuople of dasy so iahve more room to post picutre again of my up coming event as soon as i find to to fiddle wiht my car again
http://www.supramania.com/forums/showthread.php?t=18495&highlight=nashman
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well money really and i have such nice 92 and the mk3 is really heavy even if ti 3000 pounds still heavy
and i don't race as much as i used too and still can use my 92 for that anway and be more fair of class as well
tank moblie vs small littel tire rooster sucks \ ifs tank moblie vs 4 link tire burner = looose
so i do like to drag and auto x when i cna but i really in the end have to pick diffent shell if i wana take things serliy
but in the end it will be toyota with 7mgte and r154 tran's drag out auot x
right nwo i might be gettign another mk3 for rally
