Dimman;1875728 said:
For me a lot of it has to do with understanding the 'why', not just copying the 'what'.
A spring (coil) rate tells you basically nothing without knowing a lot more information. You want properly matched shocks, and just give your coil rate to a shock valver/builder guy nothing productive will happen. Wheel rate is much more useful, and for that you need coil rate, mounting angle and leverage/motion ratio. Beyond that there is frequency, so you also need to know the unsprung and sprung weights on the corner. Frequency also is a better comparing method for 'hardness' of a suspension (with same shocks).
The other issues are intended use isn't as extreme as a Group A car (see above) and preference. How much the springs control vs the bars. That's what my plans for auto-x and track days will be for. I want to be able to make good decisions, or at least ask good questions, when it comes to making changes.
I understand your point ,I have engineering degree and appreciate the theory behind the numbers HOWEVER there are a lot more variables in the "right spring rate" equation than what we know. That is why with MA70 I follow the Kent Rafferty (who is Natinal SCCA Autocross champion with Supra) rule of thumb - stiffer is better. I can't agree more with you on the fact that for the proper valving you have to know the suspension parameters. I personally had Tein RAs with 10% over spring (20KG springs) and found these to be a little too stiff for the kind of tracks I'm running on and my weight (3040) ,thus I settled with Buddy Club racing Spec Dampers and 18KG springs.
Here is the info that I have on the "big dogs" spring choices for MA70:
John Smith AUS Group A program (
Source) - Front = 28.5KG , Rear = 17.85KG
TRD/TTT Group A 1989 Setup (
Source) - Front = 70KG
TTE/MIL (Used on MIL cars ,and possibly on Bemani and RAS) - (
Source) - Front 21KG ,Rear 14KG
Interesting fact is that there are only 3 Supras in the world , actively participating in serous historic races and they all have 26 to 28 Springs in front ,that is
Alexander Strik from Holland and
David Scriven from UK. Keep in mind that all these cars ,including John Smith's supra ,are HEAVILY penalized with weight ,due to FIA regulations...
Top of the line Aftermarket Dampers such as Tein RA ,Cusco Zero 1&2 ,Buddy Club racing spec ,etc
ALL USE the same exact springs 18kg front 10kg ,end of story
