Mildew Smell from AC
92turbo4life
1,289
wherever
i sprayed fabreeze in my vents and let is saok for a while. also i recharged the air. now its cold and has the fresh air smell:)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
It's growth on your evaporator, a common AC problem. There are products made just for this but many people spray Lysol or similar in the fresh air intake to kill it. And check to see if your evaporator drain is clear.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Like Tony said. Check the water drain tube at the firewall down under the heater water valve under the hood. With the fan on high, you should be able to feel air coming out of the rubber tube. Its purpose is to allow the water that condenses on the evaporator to drain away.
They sell stuff that works really good at cleaning the evaporator and heater core, and the inside case. BUT...it cost like $25 for a kit.
Try this first.
With the car running, a/c on, I just put the controls to high fan, vents, and outside air (not recirc). Then I go out and spray 1/2 a can of Lysol (with lemon scent) into the air intake grill in front of windshield on the passenger side.
I then go inside and switch vents to floor for a minute, then defrost. That way the Lysol will get everywhere.
Do it again when it smells bad. I do mine every summer. :biglaugh:
rayall01
901
Westfield, ma
tekdeus;1360887 said:
Any other products that work well for this that can kill the bacteria? All the Lysol products only come with heavy scents now, nothing unscented.
How about straight alcohol in a spray bottle?
