Hey guys, in the process of rebuilding my R154 and am having issues figuring out if I have the output shaft center bearing in far enough. Can anyone tell me what I should be measuring between to check the 1st gear thrust clearance?
I'm measuring around .73mm between the inner bearing race and thrust washer, I've put it back in the press a couple times and am afraid to crank down on it any further so any help would be grealy appreciated!
