Massive oil leak, only when running
econti
Sydney
I've got an oil leak that only appears when the car is running. It's from the front (I think, hard to tell), and drops quite a decent amount.
I'm in the middle of doing the head gasket at the moment, and so head is off, is there anything that springs to mind that I should check at the moment?
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
Also make sure you don't forget to add fipg on the headgasket surface by the timing cover. If you do forget, its just a matter of time before it leaks.
econti
Sydney
sheedy126;2005209 said:
oil pan gasket, front main seal? loose fitting on one of your oil cooler lines possible
Will check all three now. Anywhere else that's a standard place for it to leak?
Are they the two bits right on the front? I'm following a guide, has it in that so I shouldn't forget :icon_bigg
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
generally you can follow a leak right up to where its coming from since there will be fresh shiny oil coming right from the leaking point, then dirty oil pretty much all around it.
but since you have your head off it will be kind of hard to tell
755hp
Goal - 755hp
Jul 19, 2012
164
Tri-State Area & MI
Check the front main seal and cam seals. I have the same issue 7mgte; I just ordered both the front main and cam seals from Driftmotion on Friday.
Oct 11, 2005
3,822
26
Thousand Oaks, CA
