manual boost controller
jdemara
285
North Delta
there should be a hose going from the turbo compressor side outlet to the wastegate actuator approx 3" long..
install the hose from the actual turbo to the inlet side of the boost controller (indicated by an arrow usually, for inlet). and the outlet side goes to the wastegate.
basically your just taking that vacuum line and putting in an in-line valve to restrict the psi, therefore fooling the wastegate and allowing more boost.
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
88supramaniac;1296644 said:
how do i go in installing this thing... i have everything i believe i just dont know how to.
Vac line goes into mbc from wastegate and wherever u get your boost reading from, ie intake mani. Twist to increase pleasur...er...uh... Boost lol
MA71
52
Seattle, WA
Maybe I'm misunderstanding the information but aren't these two different answers??
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
listen to the first response. its just a variable valve that goes in between your turbo and your wastegate. simple
Mikael_7m
Built 7M
Apr 26, 2009
283
Australia
Awesome.....this is well explained!! im doin this asap!!
