I wanna make sure I got the right parts, the GTE stuff is for GE also in this case right?
Cant wait:evil2:
BTW, the head on the connecting rod bolts, what the hell do I use to tighten them?
and I thought this was getting done this weekend.Yellow 13 said:Machine shop?
Yellow 13 said:I'd go with toyota bearings, I havent experienced a problem with them as long as they dont get starved for oil.
jdub said:Like Yellow said, bearing come in stock and oversize...you will need to measure the ID of the rod end and the OD of the crank journal to determine the correct size. The rod end need to be dressed out at minimum...micro polishing the crank journals should also be done. The bearing clearance (it's in the TRSM) on this motor is critical...if not done right, you're asking for rod knock.
I'd spend the coin on ARP main bolts as well![]()
phoenix6 said:how much and where, dealer only?
Yellow 13 said:What if your just replacing old bearings with new toyotas of the same size, would micropolish and rod ends be neccesary?
I'll be doing new bearings sometime next week and if it is necessary Im just gonna do the mains while the cranks out as well then.
phoenix6 said:well, there were no scuffs where the one rod was knocking, it knocked for 2 mins b4 car was shut off for good. Im only wondering why Titan allows me to just say I need 6 bearings and then order? wth?
Ill find out all the numbers on the crank and rod caps tomorrow to have u guys help me, LIke I said b4 I remeber the first three rod caps were 1 - 3 - 2 (2 being the one that had rod knock)
The rod itself is still a perfect circle, and the rest of everything else is A OK, Im just replacing ALL the rod bearings bc Im getting the rod bolts as well.
