Magnet Isolation Material for Dual Walbros - Where to Buy???
csnow
Matthew 6:33
Palm Bay, FL
Anyone know what type of material is used to isolate the magnets on a dual walbro setup? Can someone post a link as to where to buy it.
Thanks in advance...
Chris
Supracentral
10
Any fuel or oil resistant rubber will work.
A big diesel truck shop will likely have some hose you can slit and wrap around the pumps.
Blackfin
Beach Bum
Jun 16, 2005
205
John's Pass, Florida
It is just rubber. Don't select anything too thick otherwise it will be very hard to get the pumps in and out of the tank.
The rubber I had was maybe 3/32 inch thick. I had two pieces of rubber but found that if I had two layers between the two pumps, the total width was two much to fit into the tank. This is with almost 1/4 inch of material already removed on each side of the pump access port.
Also, I have a pair of walbros with hanger and -6 fuel hose that I don't need and am going to sell.
