Hey guys, I've been playing lots with my MaftPro lately, and I discovered this great program that was developed for the MegaSquirt, but it allows you to import CSV files as well.
This is a much better alternative to viewing your logs within TunerPro!!
You can have up to 12 different inputs graphed, zoom in and out, playback at various speeds
Here is the program:
http://www.ideasandsolutions.biz/msgraph/
After playing with it for awhile, I realized the CSV output from TunerPro just was not cutting it! Really makes a mess of things, after playing with some hand-editing I decided to create a script
It took my quite a few hours as this was my first Excel VBS script, so most of it was trial and error!
This script will add a timestamp (assuming 10 samples / second) so you can playback the files, it also creates labels as short as I could make while still being obvious, and finally it checks a few columns that often aren't used, and deletes them if there are only zeros.
This was created with MaftPro 5.03, running speed/density for a 7MGTE MkIII Supra, without timing control or monitor in mind - so don't blame me if it messes up any of your log files! Most other setups should work just fine, but double check you don't lose a column of information you need or anything
Examples being V-Out 1 and 2 and the 2 redundant MAP, Boost columns, etc...
