maft pro
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
i just got my maft pro but i just need to know what type of connector do i need from the maft pro to my laptop..im running vista
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
You will need a cable that goes from serial (RC-323) to usb as I very highly doubt your computer has a serial port. Hope that helps, last I heard there were problems with the maft and Vista connecting.
dumbo
1,913
Albera, Too Far North
I have no problems with connecting with Vista.
But after I cut the R7 resistor for timing monitor, I have to do a few unique steps to get it to connect:(
Labtop is a priceless tool when tuning, its faster, and no to mention the data logging....WOW
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
i read about the R7 resistor before i got my mp..you need it when your going into speed density right?...which is the setup i have...do yall have the link?
pb92supraturbo
FTG & the IRL!
Aug 20, 2005
172
Garage, under Supra
Which version of Vista are you running? I have Vista ultimate 64 bit but haven't tried to connect up to my MaftPro yet. I had no problem connecting with my old laptop running XP.
dumbo
1,913
You only have to cut the R7 resistor if your want to do timing monitor. It is not a pre-requisit of Speed denisty. Only a option.
Heres the threadhttp://www.supramania.com/forums/showthread.php?t=43848---Still waiting on more Dr.:)
Not much of a computer guy but under "System" it sais:
Windows Vista Home Premium, Copyright 2007.
System Type: 32bit OS.
Hope that helps.
dbsupra90
toonar
indiucky
i never had good luck running vista on mpro.
you have to remember, tuner pro (the actual software used on mpro) was designed for win98 and a 100 mhz processor lol.
also, the sewell usb adapter works best from what i've seen. the p/n is ap1102
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
i have no luck finding a bung to fit the iat sensor to mount on the intake...i got a 3/8 nipple it went in half way but it seems to taper and stop...how did you set yours in
