Maft Pro Timing Control
dumbo
1,913
Albera, Too Far North
So acording to this diagram,Timing Control, you use one of the wires for the MAP sensor???? I'm lost how where do the wire for the MAP go then? Or can you not use speed density and timing control together?
dumbo
1,913
Ok that makes sense, what about #10 pin, is that also tapped and grounded to E1 before the resistor? In that image it looks like the #10 and #4 go straight to the corresponding wire.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
The dotted lines represent the wires being cut, and the resistors are tapped. Pins 3 and 4 have no pre-existing function, so you must add those pins to the connector of the maft pro.
One leg of the left resistor taps into E1, the other leg taps into IGT ECU side. The only wires you cut are IGF and IGT, all others are tapped.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Pretty much. This is how I did it to simplify things...
After adding those resistors I of course had to re wire IGT and IGF
dumbo
1,913
Thats a clean way to do it, I like it. I'll change it in the future, gonna run no timing control as of now. Gotta get my girl running and broke in before the good weather is completly gone:(
Thanks for the help man.
