this is my tune any ifo would be great.
ok here are my settings if somthing is not listed it is at 0 or the setting from set up and this will also be posted at supra mania.
the main problem i have is when im driving easy on the throtle when i het around 2100 to 2800 the car leans out and and make the drivability bad.
tune high load
1600 +8.0
2200 +15.0
2800 +17.5
3400 +21.00
4000 +19.5
4600 +15.0
5200 +17.00
5800 +15.0
6400 +10.00
7000 +10.00
tune mid load
400 +5.0
800 +6.5
1200 +6.5
1600 +6.5
2200 -6.5
2800 -9.0
3400 0.0
4000 +20.0
4600 +25.0
5200 +20.0
5800 +20.0
6400 +20.0
7000 +20.0
tune low load
400 +12.0
800 + 6.0
1200 +0.0
1600 +2.0
2200 -7.5
af tracking
min tps 3.000
min rpm 3008
lean limit 5.0
rich limit 12.5
gain 4.8
2000 12.5
3000 12.2
4000 11.6
5000 11.5
6000 11.5
aux 0.0
air temp
212f +3.0
173f +2.0
41 +1.0
13f +1.5
-40f +3.0
tune responce
tps enrich 0.66
tps decay .80
tb size 7
tps map max 0.0
map enrich 0.60
bst enrich 0.15
map tps min 1.000
map rpm min 1536
setup
cfg use map
baro mode read at key on
f out mk3
v out1 3bar gm
finmode none
aux1 toy vaf
flow err sd/tuned
system setup
main scale -20.0
v-out set 2500
v-out2 set 3600
afterstart 1.8
lo load pt 36.4
mi load pt 100.0
hi load pt 143.0
f out 0
tm base 0.0
tm correct 1.27
af delay 0.0
fe smooth 30
use ve table #1
spk base 0.0
tune high load
1600 +8.0
2200 +15.0
2800 +17.5
3400 +21.00
4000 +19.5
4600 +15.0
5200 +17.00
5800 +15.0
6400 +10.00
7000 +10.00
tune mid load
400 +5.0
800 +6.5
1200 +6.5
1600 +6.5
2200 -6.5
2800 -9.0
3400 0.0
4000 +20.0
4600 +25.0
5200 +20.0
5800 +20.0
6400 +20.0
7000 +20.0
tune low load
400 +12.0
800 + 6.0
1200 +0.0
1600 +2.0
2200 -7.5
af tracking
min tps 3.000
min rpm 3008
lean limit 5.0
rich limit 12.5
gain 4.8
2000 12.5
3000 12.2
4000 11.6
5000 11.5
6000 11.5
aux 0.0
air temp
212f +3.0
173f +2.0
41 +1.0
13f +1.5
-40f +3.0
tune responce
tps enrich 0.66
tps decay .80
tb size 7
tps map max 0.0
map enrich 0.60
bst enrich 0.15
map tps min 1.000
map rpm min 1536
setup
cfg use map
f out mk3
v out1 3bar gm
finmode none
aux1 toy vaf
flow err sd/tuned
system setup
main scale -20.0
v-out set 2500
v-out2 set 3600
afterstart 1.8
lo load pt 36.4
mi load pt 100.0
hi load pt 143.0
f out 0
tm base 0.0
tm correct 1.27
af delay 0.0
fe smooth 30
use ve table #1
spk base 0.0
