looking to get the basic unit to start off with as a conversion as a MAP system. But, i was searching around and couldnt find how much boost i could run with the maft pro and the stock 440's. (READ: how much boost would it take to get the stock injectors to 80%. i.e. 350 hp?) they will be cleaned/flowtested before this happens.
assuming this all goes well, and i find the funds for bigger injectors, and hypothetically i can run required amounts of air through the blowdryer of choice. i could get to the say 25psi or what ever boost, just as long as i have the larger injectors to run it with out hitting fuel cut?
