MAFT Pro + Apexi AVC-R Installation...two MAP/pressure sensors?
arknotts
formerly ark86
Jan 9, 2008
461
Ohio
I'm getting ready to install my MAFT Pro and Apexi AVC-R boost controller, and I noticed that the AVC-R comes with a "pressure sensor" that is plumbed into the manifold vacuum. The MAFT Pro (in speed density mode) obviously uses the GM MAP sensor to read pressure in the manifold. Is there a way I can use the GM MAP sensor for both the Pro and AVC-R to get more consistent readings between the two? Or is it just better to use each separately?
