MA70 --> 2jz or 1uz
klittl06
New York
I have an 86.5 supra with an auto 7MGE. I plan on swapping a 2jz or 1uz in along with a manual tranny. However, I would prefer this be a 2 step process. Swap in the motor with an auto tranny sometime soon and next spring do the 5 speed swap.
Does anyone know if the 1UZ auto tranny or the 2jz auto tranny will bolt to the car. I know either I will need motor mounts. Will I need mounts for the tranny or a drive shaft?
Thanks!!!
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
if the transmission was put into three parts, bellhousing - transmission - rear housing (w/ rear oil seal). you will need the rear housing from your 7mge transmission (if they all use the a340e) and this will allow you to use your stock speedo and transmission mount in stock location. and abs sensor if applicable :) honestly not sure what else you'll need to get to work as the linkage and tranny computer are concerned i opted to go manual off the bat for this reason.. (assuming you are sticking with the uz or jz autos)
