Loss of Power
Apr 4, 2005
55
Milwaukee
I just got my car running and now it has no power at all. I have a flowmaster exhaust and up to about 2500 rpm's it is loud as hell. After that it sounds like I lost the exhaust, as in I can't hear it at all and there seems to be now acceleration to the car at all. It backfires a little bit but not all that bad. Anyone know what could be causing this?
M
MisterTurbineTwister
Guest
What you're hearing is coming from more than one source of causes.
I honestly can't say why your exhaust sounds the way it does. It may or may not be fine just how it is. Exhaust harmonics and sound pitches can change in different ways in RPM ranges to no end of possabilities. That diagnostic can't be used very well.
Do you have any other information about what you have changed or done to the car since the problem occured?
Listing your modifications and operations on the car would help a great deal in finding what is wrong with your car, if anything at all.
The backfiring problem should not exist at all. Exhaust scavenging on deceleration is normal to some extent, but this is more than likely directly related to your experiences with loss of power.
The turbo itself can act as a muffler to some extent as it does disrupt the harmonics coming from the exhaust manifold while it changes it and uses the exhaust pressure to run the turbines.
Here are some symptoms of backfiring and poor acceleration and possible causes:
http://www.cygnusx1.net/supra/library/TSRM/em/EM_05.html
I would need to know everything that you have done to the car to help any further. I would also need to know how it idles and runs otherwise besides when the problem occurs.
Apr 4, 2005
55
Milwaukee
I have a K&N FIPK and a Flowmaster exhaust on my 90 N/A. I don't think it is the harmonics and what not because once in about 20 times I will hear the exhaust through the entire gear and it will accelerate just fine. Every other time the tone fades away at 2500 rpms.
