Losing clutch???
mk3tattoos
1,104
Bremerton, Wa
When I come to a fast stop or under hard breaking, i lose all clutch pressure and it just goes to the floor.
I have to pump it a few times to get it to work again.
Any good idea's why it's doing this?
mkiiichip
1,434
WI
If there are no external leaks, its the master. But i would replace the master and slave together, and flush the system.
And get ASIN brand parts.
AJ'S 88NA
2,419
Florida
Sounds like the fluid is low. There is a float in the master and you have to look pretty close to check the level.
mk3tattoos
1,104
Bremerton, Wa
I don't see any leaks and I pull into the garage everyday and there is no spots on the concrete.
I'll replace everything and see if it works.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Pull up your carpet at the firewall and look for hydraulic fluid under the clutch master. When these leak, they tend to do so inside the car, so no spots on the concrete.
mk3tattoos
1,104
Bremerton, Wa
Ok I'll check that tonight and report back. Thanks
