So the hazards are flashing and not turning off? Did you turn them on at all? I've got a hazard switch somewhere around here... I'll check something and post back.
It is tied to all the rear lights... so rear side markers yes.
BTW - If all the rear lights are fine, check the bulb sockets for signs of corrosion (that can set off the failure module) otherwise the lamp failure module may be faulty.
yea cuz when the light turned on i checked out my rear lights i didnt see anything out but i will check again and btw where would the lamp failure module be located?
