lets talk cooling?
supra88gr
110
s dub
so i want a new radiator. which one would be the best one to get i was thinking about a moshimoto rad? comments?. and should i stick with the stock fan on the car or upgrade to electric fans? and which thermostat should i get? thanks guys for any opinions and comments
jdub
Feb 10, 2006
10,730
Valley of the Sun
I have a CSF dual core radiator...Zyrex G05 coolant.
The stock fan is good for most street cars.
Toyota OEM or Stant SuperStat...190 deg F.
supra88gr
110
s dub
Toyota OEM or Stany SuperStat...190 deg F.
thanks for the info. my car is not exactly stock . i have been running on a gt35r sut up with supporting mods and making 502rwhp and i figured its time for an upgrade. is the stock fan batter then the electric fans or no . and is the moshimoto rad any good
BoostJunkie
70
Clarksville, TN
From what I have seen around the forum, the stock fan does flow a large amount of air. If you go with electric that you need to make sure it will flow atleast the same amout if not more. Use the search I know there is a few discussions about electric fans on here.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Mine's not stock either....the stock fan is still what you want to run, especially on a built motor. If you are running the stock ECU, you still want a 190 deg tstat...that is unless you want to run rich.
Moshimoto rad? IMO, you get what you pay for.
Kckazdude
1,239
Memphis, TN
Stick with the name brand aluminum radiators from the more reputable shops. They are usually in the ~$400 range. The ones on Ebay and elsewhere in ~$250 range are not bolt in affairs and will give you greif when trying to run the factory shroud and fan. All of the lower priced ones I have seen will not allow you to run the fan shroud effectively.
+1 for the 190° t-stat.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Supra90gr;1364079 said:
Mishimoto is good. I'm running it in my car and it's great
Does the stock fan shroud bolt up without modification?
On another note (topic of cooling): would a hard lower radiator pipe be beneficial in any way, or would it be more for the "peace of mind" or "bling" factor?
rayall01
901
Westfield, ma
Bling! The pressure in a radiator isn't too high, and a good quality hose in good condition will be fine. Remember, if you use a hard pipe, you still have to attach it with hoses.
Kckazdude
1,239
Memphis, TN
On the lower priced Mishimoto's and similar rads, no.
