Lean condition=higher coolant temp?
SupraDupra500
195
Terre Haute, Indiana
Wellllllll... i installed a lex and 550's. the car feels insane under boost with my Holset turbo. Im pretty sure i'm running a little lean. would that create higher coolant temps?
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Engine temperatures will increase with higher EGT's (Exhaust gas temps) flowing.
Leaner = hotter.
Heat will transfer from the engine to the water.
Poor radiator function will not be able to maintain water temps very well.
It would behoove you to purchase a WB, so you can tune around "lean" conditions.
And possibly check your cooling system for efficiency.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
What the fuck are you doing messing with AFM's, Injectors, and bigger turbo's without WBO2?
Jon, you seem to know him, so go slap him upside the head
