leaking coolant!!
Da Bushman
Team Dutti Racing
Jul 26, 2007
Queens, NY
To the point of me having to refill the rad every couple of days and leaving pudles on my driveway. Where should i look first, looks like its coming from the radiator, not from the engine.
Da Bushman
Team Dutti Racing
Jul 26, 2007
Queens, NY
BlackDynamite said:
take a piece of cardboard and put underneath let it sit still and then see where it drips from onto the cardboard...
ahh good idea, will do, i'll have it jacked up tomorrow ans tell ya what i see
Da Bushman
Team Dutti Racing
Jul 26, 2007
Queens, NY
Alright guys, puts it on ramps and looked to see whats going on, its definatly dripping from the radiator, but i don't know where, damn thing is so rusty i can't see if anything is loose.
Can u guys tell me where the hoses are located on the radiator and if i wanted to take it off to inspect it, how would i go about doing that?
s383mmber1
3,614
Somers New York
Make SURE you find the exact spot its leaking from before you replace the radiator!
My friends car had a pin sized hole in a hose spraying onto another peice of coolant devise, and it threw us off big time!
Da Bushman
Team Dutti Racing
Jul 26, 2007
Queens, NY
Checked the hoses and everyting looks good, i'm gunna pull the rad out tommorrow, now is there anything i should look for that would be out of the ordinary? I was thinking of shooting water into it and see if anything leaks, what u guys think?
f00g00
586
Kuwait
It would be better if you put the rad in a tank of water and plugged one end and ran low pressure air in the other with the cap on of course.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
get new hoses if they lookbad, thats normal maintenance. if you still have a leak, replace the radiator, or run stop leak through it (not recommended)
Da Bushman
Team Dutti Racing
Jul 26, 2007
Queens, NY
Yeah i've seen that stop leak stuff, how does that work?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Basically, it's aluminum or nickel platelets which you pour in and pray they don't clog any thing other then the leak.
Da Bushman
Team Dutti Racing
Jul 26, 2007
Queens, NY
Alright guys i turned on the car and let it run to operating temp. The radiator started leaking again and from what i saw there was a boiling/steam sound coming from the top of radiator on the driver side and looking closely it was leaking from that area. I'll take a pic soon.
