Largest Turbo on 1JZ drewgo manifold
Andre
115
Netherlands
I am running an 1.5 JZ
Butt i heard some people have issues like boost creep on drewgo manifold wilth large Turbos
Is this correct ? is there anybody running sometheing bigger then 67
BTW what is an nice agressive street Turbo that i can use with the 1JZ drewgo Turbo manifold
I'm running the pt67 on my Drewgo with no problems at all.
What are your mods and what are your goals? Hard to tell what turbo you need without telling us what you have and what you want.
Andre
115
Netherlands
What i have is an 1.5 JZsingle Turbo running on 550CC injectors with single fuel pomp and greddy emanage piggy back
What i want is an agressive street setup so no bigger then an 70 mm otherwise to lagay i think on the street
No dyno king for me
Soon i wil upgrade my fuel by adding a second fuelpomp change my lines injectors etc etc
I am thinking something in the range of 67 to 70 mm with the supporting mods is nice voor an agressive street setup ?some body correct me iff i wrong pls
rwd
60
quebec
i have gt4088r dbb .95a/r on my 2jz,it's 63mm,and i think i have very nice powerband for street,very good turbo response and it's close to a high 10's car on quarter
i actually have 525whp 505wtq on 18psi no cams,i expect 670whp at 25psi and hks 264's
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i ran my old setup of a 72mm on a drewgo style manifold, never had any boost creep problems with it.
im running a T88 on it now, but ive only driven 25 miles on it. so i dont know if this turbo will have that issue just yet
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i'm on a 70mm with the drewgo manifold and never saw any boost creep issues... do you like your power at tap or can you wait for a spool? if you like your power almost instant i would to with somthing no larger than a 63mm but if you want full boost in the higher rpms i would go with a 68mm or a 70mm
