Koyo radiator cap
smagnotta
SuprSal
WashPa
All,
I bought a Koyo radiator for my MK3. What radiator cap do you recommend? The stock PSI is 13, but what about a Greddy one:
Greddy high-pressure radiator caps are OEM style radiator caps, which means they screw on just like the factory radiator caps. Not only does the metal GReddy Badge on the cap dress up your engine compartment, but the 1.3kg/cm2 (18.5psi) pressure rating increases the performance of your radiator.
Any suggestions?
koulee
497
The stocker would suffice. What kind of setup you planning to run, power-wise?
smagnotta
SuprSal
WashPa
Up to 450 HP. There is the TRD rad cap too. I am wondering if increasing the pressure from stock 13 PSI to 18.5 PSI has any detrimental effects ?
