knock sensor code questions need advice and expertise
supraking16
93
georgia
ok i have had the 52 code come and i checked the wires its pretty bad looking. so i ordered two new plugs and ill rewire them. its also allways showing code 21 o2 sensor but its allways been there i had some wires touch and ever since its stayed on no matter what o2 sensor i put on it but i noticed i can reset the ecu and code 52 will stay off the code 21 will always come backon right when i crank it unless i get on it and build some boost. the head was just rebuilt i also installed bc 264's it runs good but i noticed when i boost its goin to eight pounds. my turbo is stock no boost controller not even aftermaket intercooler just the pipes on top are aluminum and a blow off valve. could a boost leak right at the compressor housing cause it to hit eight pounds. and could that cause the knock sensor code to fire do to more boost. if it was bad wires wouldn't it allways come on. if i drive the car easy it will stay off. p.s. the exhaust is three inches all the way to the back from the turbo i also have aem afr and it allways is looking good when at full throttle it goes to eleven is steady. is that how rich it runs when at full throttle. thanks to everyone
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Without going into detail certain parameters must be met before 52 sets. Speed, time, rpm, stuff like that. Just fix the wiring and you should be fine.
The 21 is because there's no current flowing through the O2 sensor's heater. Not a big deal (the sensor still works when hot) but it should be fixed to put the engine into closed loop quicker and prevent it from falling out of fuel control during prolonged idling.
