K&N FIPK compatible with Lexus V8 AFM???
89pearlwhite
23
Houston, TX
A question, does anybody has a set up with K&N FIPK with Lexus V8 AFM ??? If so did you have the FIPK kit for the Supra or for the Lexus? If it is the Lexus what year and model?? Any help is appreciated.
lagged
1991 1JZ
new rochelle
MKIIINA said:
it fits.*
* you will need to use different bolts and play with it some to get it to fit flush.
depends. i have 2 lexus AFMs and oddly enough, one of them has threaded holes for the filter, and the other one dosnt.
MKIIINA
Destroyer of Turbos
Plano, TX
really? interesting..... did all the bolt holes line up correctly? i got 2 to line up exactly, 1 to get really close and the last one i played with for a while before i drilled the hole a touch and got it to fit exactly right. mine was the non tapped version. went vpc so dont have to worry about it any more :)
