JZGTE VVTI Swap into RX& Starting Issue
suprapdbojay
Monessen PA
I have an 1986 RX7 I put at 2JZ VVTI engine in. I just got everything wired in. It cranks and starts for about 3 secs and shuts down. Any ideas? I would really love some help. Thank you
Jai S.
NY
assuming its a 2jGE vvti? if so, is MAF sensor plugged in? Sounds to be more of a fuel problem to me, before dropping in motor, did you take apart motor? mainly the fuel rail or injectors? If so, the O-rings on the injectors maybe be bad or may have fallen out. A similar problem happened to a friend of mine, turns out one injector was missing an O-ring and as soon has he starts, motor starts to back fire and stalls. Hope this helps in some way! Good luck,
