I've Tested the Best Penis Extender During 6 Months: ~ Honest Review/Results
powerdude
My 6-Month Journey Testing 5 Top Extenders to Add 2 Inches — Here’s What Worked Best
For a long time, I had a personal goal that many guys secretly share: to increase the size of my male organ. I wasn’t looking for shortcuts or gimmicks. I wanted a safe, proven method backed by real users and ideally supported by medical facts. After browsing dozens of forums like PeyroniesForums, Tundra's Place, and Reddit threads, one thing became clear:
There's no one-size-fits-all extender. Everyone's body is different, and results come down to comfort, commitment, and the right device.
So I decided to do something few actually do: buy 5 of the best-reviewed extenders and test each one for a full month. After that, I’d choose one to wear exclusively for 6 months.
The Devices I Chose​
Setup & Assembly​
Each device had its own setup experience. Here's how it went:
  • Quick Extender Pro: Assembly took under 10 minutes. The Double Strap System (DSS) is intuitive, and the rods adjust easily to your size. A big plus for beginners.
  • Phallosan Forte: More complex initially due to the vacuum bell and belt system. However, it becomes second nature after 2-3 uses.
  • Penimaster PRO: Most professional-feeling. The suction chamber is medical-grade, and you can wear it with either rods or a belt. Setup took about 20 minutes.
  • Total Man System: This one includes everything — vacuum chamber, weight system, extender, and compression sleeves. Expect a steep learning curve but incredible versatility.
  • SizeGenetics: A rod-based classic. Comes with many comfort pieces. The strap system takes getting used to but is effective.
One Month with Each Device​
#1. Quick Extender Pro
  • Daily Wear Time: 5–6 hours
  • Comfort: High. DSS straps felt secure and reduced slippage.
  • Results: ~0.5 inch in 4 weeks
  • Experience: I liked that I could wear it under my clothes. No pinching, no numbness. Adjustments were easy.
#2. Phallosan Forte
  • Daily Wear Time: 6–8 hours, often overnight
  • Comfort: Outstanding
  • Results: ~0.4 inch
  • Experience: Wearing it while sleeping was a game-changer. Gentle traction over long hours made it very effective. The only downside: it can loosen during sleep if not fitted well.
#3. Penimaster PRO
  • Daily Wear Time: 5–7 hours
  • Comfort: Excellent with the suction chamber
  • Results: ~0.45 inch
  • Experience: Very medical, very secure. There’s a vacuum bulb that forms a perfect fit, reducing any slipping.
#4. Total Man System
  • Daily Use: Extender + hanging + pumping
  • Comfort: Good but requires practice
  • Results: ~0.35 inch
  • Experience: Best for advanced users. I appreciated the weight system, which helped break through plateaus, but you need discipline and time.
#5. SizeGenetics
  • Daily Wear Time: 4–5 hours
  • Comfort: Medium to high, depends on padding used
  • Results: ~0.3 inch
  • Experience: Classic design, similar to QEP but not as secure. Strap slipped occasionally. A solid all-rounder, especially for beginners.
Why I Chose Quick Extender Pro​
After five months, it became clear: Quick Extender Pro delivered the best results for the least amount of hassle. The DSS system evenly distributed pressure, reducing soreness. It was discreet, so I wore it while working from home. I gained 0.5 inch in the first month, and 1.5 inches by month 3.
So I committed to using QEP exclusively for 6 months.
The 6-Month Results​
After completing my full test period with QEP, I hit my goal:
  • Length gain: +2.1 inches
  • Girth gain: +0.5 inch
  • Total hours: ~700
Most importantly, there were no injuries, no side effects, and my confidence skyrocketed.
Tips for Others​
  • Start slow: First week, only 1–2 hours a day.
  • Track progress: Weekly measurements keep you motivated.
  • Clean everything: Prevents irritation or issues.
  • Follow a program: I used a mix of traction + rest days.
Final Thoughts​
Each device has strengths:
  • Use Phallosan Forte for overnight comfort.
  • Choose Penimaster PRO if you want suction tech and clinical quality.
  • Go with Total Man System if you're into advanced stretching & pumping.
  • Try SizeGenetics for a solid entry-level experience.
But for the best blend of traction, results, and comfort, I’m sticking with Quick Extender Pro.
Stay consistent. Measure weekly. And believe in the process. The results are real — and worth it.
powerdude
How I Assembled and Used Each Extender​
Quick Extender Pro (Deluxe Edition)
This was the first device I tested. The assembly was straightforward—less than 10 minutes. The Double Strap System (DSS) clicked naturally into place and adjusted easily to my size. I followed their routine, starting with 1–2 hours daily and moving up to 5–6 hours. It was very discreet, so I used it while working from home. The comfort level was high, no numbness or slipping.
Phallosan Forte
I had to get used to the vacuum bell and belt system. It took a few tries to fit it properly, especially at night. But once you figure it out, it’s one of the most comfortable devices. I wore it 6–8 hours overnight and felt gentle, consistent traction. The key was to get the right sleeve size.
Penimaster PRO (Complete Set)
This felt the most "clinical." The suction system required a bit more prep: heating the chamber, prepping the glans, and sealing properly. It comes with both rod and belt systems. I switched between them and used the bulb to make a vacuum seal. I wore it 5–7 hours a day and tracked steady gains.
Total Man System
Honestly, this one took the longest to master. It’s more like a full gym for your member—vacuum cup, weighted hanging, compression sleeves. I used it mostly for manual stretching and some hanging with low weights. I wore the extender setup for 4–6 hours and added pumping sessions twice weekly.
SizeGenetics (Ultimate Package)
It’s a classic rod extender. Setup took some time with all the comfort attachments. Once set, it held the glans fairly well, but I noticed occasional slipping. I used it 4–5 hours daily and appreciated the instructional DVD they provide. Results were modest but consistent.
What I Learned From Daily Use​
  • Consistency is key: Skipping days noticeably slowed results.
  • Tracking matters: I kept a log of hours and size gains.
  • Comfort = commitment: If a device was painful, I skipped it. That’s why Quick Extender Pro became my go-to.
By the end of the testing period, I committed fully to Quick Extender Pro. It offered the best balance of comfort, traction, and usability. I wore it for 6 months, averaging 5–6 hours daily. By month 3, I had gained 1.5 inches in length. After month 6, I hit +2.1 inches in length and +0.5 inch in girth.
Final Results​
  • Length: +2.1 inches
  • Girth: +0.5 inch
  • Total wear: ~700 hours
  • Side effects: None
My Tips for Anyone Starting​
  • Choose your extender based on comfort and your lifestyle (daytime, nighttime use).
  • Follow a progressive routine: Start small, build up wear time.
  • Be patient: It’s a long game, but it works.
Summary​
Each device has unique strengths:
  • Use Phallosan Forte if you prefer overnight wear.
  • Try Penimaster PRO for a medical-grade suction system.
  • Choose Total Man System for a full stretching + pumping approach.
  • Go with SizeGenetics for a basic, proven rod extender.
But for the best combination of comfort, traction, and results, I fully recommend Quick Extender Pro.
Visit the official site to order QEP with a 20% discount: https://geni.us/qep20
Stay committed. Track your gains. The change is real and worth it.
