it happened again....
E.l2ice
13
Portland, OR
when i try to check codes, it blinks constantly, like nonstop. the last time i did it i starred at the blinking check engine light for like 5 min without it pausing once. Its probably because of the auto to 5speed conversion. and... CPS wires?? huh.
johnathan1
Supra =
Aug 19, 2005
5,056
CPS=Cam Position Sensor...it's located right behind the exhaust cam gear on the turbo side of the head.
Wiggle the wiring to it a few times in a few places, and see if the car starts.
Then report back. :)
edit: Does the tach needle bounce slightly while cranking?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
CPS is on the on the passenger side of the motor right in the front, there is a big green connector sitting on top. Wiggle it around as everyone else as said.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
Mine does when i try to start, along with a million clicks.. lol
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
It may be grey instead of green. I don't know what year they switched though...
Anyway, I circled the plug and top half of the cps in this pic.
E.l2ice
13
Portland, OR
uh the previous owner spliced a shit load of wires from that area. dont really know which one cuz everything is all messed up.
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
The plug closest to the valve cover appears to be the Cps connection, but I can't tell which wires are going to it on the far side.
E.l2ice
13
Portland, OR
the idiot that i bought the car from, looked like he tried to wrap that thing with like 10ft of electrical tape and a zip tie...
csolstad
33
Clinton, NJ
definitely CPS wiring, i had the same EXACT problem and i fixed it by figuring out which wire had a weak connection and soldering it
i suggest you take apart the mess thats there and get each wire so its separate, then reconnecting them by using crimp connections or solder.
do a search and u can find which color wires match to which
