So I just got to test some new things on my car in order to get it started. This is what I came up with:
When I disconnect a yellow plug that connects some wires from the ECU to the fuse box(directly to 15A EFI fuse) and turn on my ignition I do not blow the 15A EFI Fuse, however with these wires connected the fuse will blow when I turn on the ignition. This leads me to believe that there could either be something wrong with my ECU or the wires that run in between the yellow plug and the ecu or the yellow plug and the fuse box.
I believe that I have all of the wires from the harness hooked up correctly, which i'm going to triple check today for loose connections or something I may have missed on the harness. I also checked the ECU and I get correct voltage readings for what I was able to check with just having the ignition on and battery connected.
I tried to run the Diagnostic Check and it did not work, my check engine light would not come on and I suspect it is due to the fuse that keeps blowing.
I have my ECU out of my car and am about to take it apart to take a look inside to see if anything is burnt from when I could have possibly shorted it.
Is there anything in particular I should look for when exploring my ECU board, and also should I be concerned about the state of my harness from after when I screwed up and shorted it the first time?
Is there anything else that I should look for?
