Completely disassembled, cleaned, inspected and lubed shaft with minimal amount of white lithium grease.
The shaft and pintle appears to slide easily when compressing by hand, and returns with just the spring tension, without the stator housing in place. And the bearing feel smooth.
Assemble it all back togather, test with + power to the 2 middle posts and ground applied individually one at a time outer 4 posts and it just clicks, not any visible movement.
Anyway, is this an item that is generally ok to buy used or just bite the bullet and get new?
Strange thing is before removing and cleaning car would not idle cold with it plugged in. Unplug it and restart and it would idle at approx. 1200 rpm.
