Is this the right part?
supraman74
I bought it SUPPED up
Apr 26, 2007
89
Iowa
I ordered the N/A oil filter stud from Toyota...
http://cygnusx1.net/supra/library/EPC/MKIII_NATO/291410/1502_1.html
I just want to confirm that I got what is pictured above...
It just seems short, about 1 1/4" long.
Also, do I need any type of O-ring or thread sealer on it?
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
According to the diagram that you linked, it looks correct to me. I'm not sure about the o-ring. I would think that it would be a washer. But, you could probably use some teflon tape on it.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
I would probably put some thread locker on the side that goes in the block..I remember one time i was changing the filter on my honda and the stud came out attached to the filter..i was like wtf??? So i put some thread locker on it and it never happened again..Maybe its just hondas meh..
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
I guess it wouldn't hurt to put thread locker on it. It's not like it needs to come out again (unless the filter side gets stripped). But, that's just a socket and some muscle away from coming out.
supraman74
Apr 26, 2007
89
Iowa
Thanks for the replies.
I'll probably have more questions when I get my oil filter relocation kit from permacool.
Thanks again!
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
jdub;893844 said:
and since you're relocating the filter, you should not need Lock Tight either.
Oh yea i didnt really think about that. For some reason i was thinking he was just putting the filter on it lol.DUH
O and thanks for the link jdub i needed that!
Oh and ^ why did you bump it??
supraman74
Apr 26, 2007
89
Iowa
BTW, the part# listed in the TSRM for the N/A stud (15600A) has changed to (90404-20173)
I used the old# at the dealer and it comes up as a discontinued part so I was ready to give up when they called me back and gave me the new#.
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
15600A is not (and never was) a part number. It is a PNC (Part Name Code). It's the same number on all Toyotas. It's just an easy way to find parts in the catalog. If the dealer didn't know this right off the bat, I'd say they were n00bs, or just having a bad day. ;)
90404-20173 is (and always has been -- never changed) the part number.
When looking stuff up in the EPC, the numbers in the diagrams are usually PNC's. (Unless they're 10- or 12-digit numbers). You can use them at the dealership, but they don't tell you any information about year/colour/application, as they are NOT Supra specific numbers (They're the same in all Toyota Catalogs).
Click on the PNC in the EPC and it will give you a list of actual part numbers.
Jeff
jdub
Feb 10, 2006
10,730
Valley of the Sun
If you are going with a full flow cooler circuit like I describe in the above thread, you will have to block the old oil pan return and that is correct size bolt to use. Also get an appropriate size oil pan washer to use with the bolt.
supraman74
Apr 26, 2007
89
Iowa
I need a little help with the hose fittings.
I dont think I want to use the barb fittings that came with the permacool kit.
It looks like I'll need some 90deg. or maybe 45deg. bends coming off of the filter adapter thats on the block.
I'm lost when it comes to an, npt and so on. I dont want to buy the wrong stuff.
Any help or ideas or even pics of what you guys used to do your setup would be great...
Thanks for all the help and input so far!
