Is the the correct ECU for my 2jz-gte?
Flateric
946
Calgary, Alberta, Canada
Here's an easy one for you guys, I just want to be sure I got the correct ECU for my jap-spec 2jz-gte I am currently swapping into my ma70 mkiii.
My reasons for doubting my current one are that I didn't get the engine I had originally compression tested on friday when I picked the engine up on monday. However the engine I did get may not be as shiny and "pristine" looking it did however compress test better than the engine I tested on friday. Shadey yes you bet!
The ECU I got with the motor is a 2jz-gt. The only reason I ask is perhaps it should say 2jz-gte on the ECU?
Thanks in advance for any help.
