is the manifold worth it?
With the waste gate that's a good deal.
Pro's takes a bigger turbo.
Cons bigger turbos cost more money.
san supra
833
san antonio
will i have to relocate the oil filter?
how would i support that heavy thing?
i was thinking for future use because im guessing you dont see them to often
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
HKS is sooo quality
I'm assuming that you wouldn't have to relocate anything, and it might have a mount for a bracket similar to the stock turbo mani.
Sam
So far as I remember it clears the stock oil filter setup (though it's a crap setup and should be replaced if you're serious about your motor). Main issues are it won't clear a big turbo without a spacer (don't remember the largest turbo it can take), you'll need to have a custom downpipe made, and of course the oil/coolant/IC/filter for the turbo has to be covered.
It doesn't use any of the stock bracing, but people have used em fine for years...
