Is it safe to wire in my aftermarket ecu and 1jz igniter to the stock EFI relay ?? Vipec v88 ecu
R Raggan New Member Mar 16, 2015 142 0 0 Maple Ridge, BC Oct 24, 2017 #1 Is it safe to wire in my aftermarket ecu and 1jz igniter to the stock EFI relay ?? Vipec v88 ecu
EEPerformance17 New Member Oct 19, 2017 3 0 0 55 US Oct 29, 2017 #2 Raggan said: Is it safe to wire in my aftermarket ecu and 1jz igniter to the stock EFI relay ?? Vipec v88 ecu Click to expand... That's typically what you would do. Everything on the engine runs off of that relay Sent from my XT1585 using Tapatalk
