intercooler question
MOON
34
calgary alberta
im thinking of buying the intercooler kit from driftmotion, 24 x 12 x 3, this is the same size as wats on car already,factory, its been hit so need new, now my question is, the d/m intercooler has 3 inch in/outlets,i was going to go 2.5 in piping, should i just go 3? would it make a differance on lag, im kinda new to the technicall side of turbos. and 1 more wat kinda of blow off valve would be good, its stock twins. thanks in advance.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I can get you an intercooler that is the same size with 2.75" inlet and outlet for the same price if you want. It really doesn't matter much. We usually use the 21x9x3 core ic with 2.5 in/out, it flows enough for 600whp+, and it fits better so it's easier to install.
