Installing Flexalite fans
RIPDOTCOM
157
Tallahassee, FL
I have a set of flexalite fans and want to set them up for "Always On". Obviously The ground isnt a problem but whats the best place to connect the positive so they come on when I turn the ignition on.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
there is thread some where in here that i explain on how to set it up and such
so fidn the thread and you will get your answer
for teh remote wire use the ig on postion this why when you crankt eh fan is not on robbing power from your starter when you are starting your car
not the acc wire thou
dbsupra90
toonar
indiucky
it will work better if you space it ~1" from the radiator. use some of the universal stripping from autozone/advance/etc. the home grade stuff seems to fall apart under heat so i would recommend the automotive kind.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
yeah your best bet is to find something else always on, check the TEWD, i dont have hte link now but just google it
