Installing Bomex Type rear skirt ?'s
Steve_N
Louisville KY
Whats the best way to install these? I see the place to bolt them on in the tire well but do I use moulding mounting tape or an epoxy on the bumper or what? Also do I need to remove the rear mud flap? I intend on getting them molded in when I get my car completly repainted next spring. I just want to make sure they are mounted securely till then.
Thanks
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Good quality 3M double sided tape, and prep the surfaces properly with isopropyl alcohol and they should stay up fine.
Molding them in is the better idea, but temporarily, double stick tape will work.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
3m makes some wicked double stick automotive tape. id try to find a roll of that.
