Installing aftermarket steering wheel
Aug 12, 2010
347
P.G. County, Maryland
:1zhelp:I really like the limited edition NRG wheels. 350mm deep dish, for under $100 from Grimsta.
1). I'm confused about the items needed for an install. It should go: car>hub>wheel,right?
2). A quick release ian't a deciding factor, but it would be nice. If i was to use one, would it take the place of the normal hub, or does it fit on top of it, changing the order to: car>hub>QR>wheel?
3).In the case of the adapter, is this what the hub itself does, or do i need to buy a seperate adapter in addition to it? IE: car>adapter>hub>QR>wheel?
IM SO CONFUSED. AAARRGHHH.
Cz.
CAR > FAMILY
Seattle, WA
1 and 2 are correct. The adapter, if I'm understanding what you are asking, is the hub. The hub bolts to the steering shaft and you should be able to bolt a QR or a wheel directly to the hub.
