I'm retarded or something
Jeff Lange
Administrator
4,926
17
Sunnyvale, CA
jefflange.ca
The only thing there should be with this "mod" is a diagram. Original, and what it will look like afterwards. If you can't figure it out from that, I suggest not doing it.
Randomly cutting "X" coloured wire and hooking it to this and that is just asking for trouble, you need a wiring diagram for your year. :)
T
turbo06
Guest
well i'm just splicing all the wires back together so can't go wrong there right?
supra90turbo
shaeff is FTMFW!
MA, 01440
I like Joel's method quite a bit.
JJ, You should make a good writeup! You and Dylan should collaborate on a How-To, even using different years...
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Sorry guys, I'm leaving for my summer abroad in a few days. No time to mess with this right now but I'll work something up when I get back. Doing it Nick's way is simplest or do you want the fog lights interlocked to something besides ignition? I'm assuming you want to retain the auto off function?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I can take my switch apart and take pictures if you guys want to see how I hacked the switch..
No wires were harmed or hacked during the modification.. The auto off function still works (unless I let the turbo timer count down after the door is closed).
I am kind of wondering what the switch was supposed to look like..:)
