I'm breaking up on the top end. Spark plug gap recommendation please?
Suprapowaz!(2)
2,870
San Antonio, Tx.
I'm running Autolite copper 3922's @ 0.031 gap.
16 psi on a Garrett T4 60 trim. AFR's are at 11.7.
Shell 93 octane gas.
Car is breaking up after 4200 RPM to redline.
I have not done the ignitor "mod".
Should I close the gap on the spark plugs? What would you guys recommend?
Suprapowaz!(2)
2,870
San Antonio, Tx.
I'm guessing cause the fuel mixture is good. Could it be something else?
BTW, I didn't have this issue when I was running 12psi. I bumped it up a little and now it's here.
Suprapowaz!(2)
2,870
San Antonio, Tx.
Fixed.
I pulled all the spark plug and checked the gap. They all ranged from 0.035 - 0.039! Last month when I put them in I didn't have a spark plug gapper tool, so I used a feeler guage to gap them. Turns out I did a sloppy job and gapped them too much. I found my spark plug gapper and re-gapped them to 0.028. I took the car for a spin and the break up is no longer an issue.
gsxr141
1,158
10
rochester
kind of a related question.... i finally installed new plugs, but i went with autolite 3923's. i see that everyone is using 3922's. should i switch to those?
