Illinois: Experienced Supra Owner Needed for Head Gasket Repair
TobyCat
470
Vancouver BC
Oh yes, earplugs! Get the ones that have cords attached to them so that you can get them out easy.
A 3 angle valve grand is when they take the valve out, clean it up and make sure that the outer ring is perfectly true. Often times the edges of a valve will be pitted and covered in carbon. In order to insure that the valve seals up properly they will 'sharpen' it.
Shimming the car is similar to doing valve lash. Underneath the lobes of your cams are shims. These shims vary in thickness and are designed to allow a certain tolerance between cam lobs (this is where feeler gauges come in). The problem when getting your head totally rebuilt is that all of your shims need to be re-calibrated to proper spacing. At about 8 bucks a pop and 24 in a car, it can get expensive and is time consuming. A machine shop should have them in stock of all sorts of thicknesses and they'll just swap out as they need.
iwannadie
981
gilbert, az
I couldnt find the ones with strings. I used normal ones and have a pick that pulled them right out. Im sure a paper clip bent would work just fine too.
7afe
Evanston IL
I just had my BHG job done at my shop in villa park. Y2K performance 752 N Yale Ave. Villa Park. Ask for Gen, and tell him Felix sent you.
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
Damn, that's pretty close too. Unfortunately, I already have EVERYTHING apart, lol. Maybe I'll tow it there when I can't get it back together.... lol. Anyway, good to know - do they do machining in house, or send it out? Price?
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
I also was going to send my motor to them to have them work on the block and to put it together. They also worked on tons of MK3 supras as well so they know what they are doing.
Also their phone number is 630-544-0089
dugums
Apr 10, 2007
699
Chicago, IL
Well, it's good to know of a place I can bring my car for any other repairs I might need (and don't have the time for).
On the one hand, IF I can get everything back together OK, I will be happy I did this myself (albeit with some help) I feel I have learned a lot tearing this down. On the other hand, it has taken a LONG time, and a considerable amount of money.
dugums
Apr 10, 2007
699
Chicago, IL
starscream5000 said:
I don't know if anyone ever told you this, but I'll go ahead and let you know just in case you didn't.
Welcome to the money pit ;)
Yeah, this is not my first. Just my first attempt at repairing something like this on my own. I thought it would be a great learning experience (which it is) and that it might save me a few bucks (which it isn't, and quite frankly if all goes wrong, I have nobody to blame but myself, lol :icon_razz ).
