Over the course of a couple of months, the typical Supra "Idle Bumps" have been increasing and it is also showing up under load. At WOT, it almost feels like a slipping clutch. My clutch is new...
I have tried three different stock coil packs, two igniters, and my plugs and wires are new. One noteworthy thing is that at cold start, there are no idle bumps whatsoever.
About two weeks ago I got a code 14. I know that it is related to the IGf signal and is activated when the TCCS does not see three consecutive "fire" confirmations from the igniter. I cleared the code and it has yet to return.
So, I sourced a set of MK4 2JZGE coils and in doing some troubleshooting to figure out why my COP's would not run the car I found out that the coil for Cylinders 2&5 fire at the 'Key-On' position.
Here are my questions:
1. Is it normal for that coil to fire at the 'Key-On' position?
2. Why does this seem vary between years of manufacturer? (My car is a 91)
3. Why does the coil fire at 'Key-On' position?
Thanks!
-Kenny
Thanks!
-Kenny
