identify pre89 injector resistor
JASONA70
nomnomnom
Oct 27, 2006
743
socal
I think this is a pre 89 injector resistor
I just need to know which one is the ground wire. I think it is the white one but i am not sure, if anyone could chime in and identify this. I am wiring this to my 1JZ 550 injectors.
another question: Does it matter which resistor wire I use to wire the ground for the injectors? I was thinking I could mix up the resistor wires because it is just a big chunk of resistors inside.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i dont think it actually matters as long as you wire injector pairs into 3 of the wires and 1 of the wires back into the line they all merge to
JASONA70
nomnomnom
Oct 27, 2006
743
socal
If anyone is interested I flowed/Cleaned my injectors. I know in the past people had some doubt about USDM 550's but it seems like mine came out just fine. I've read on a couple of threads that some 550's flowed close to 440's, and some flowed at 550.
